How to take apart the opti?
I am goginto be putting on a LTCC kit, i need to know how to take out the cap and rotor on the opti, what size are those little screw thngs? and what do i need to be careful doing, and how should i seal it back up again?
The tool to take the optispark cap off will cost you $0.85.
http://web.camaross.com/forums/showt...ight=optispark
Nuff said.
Nuff said.
http://www.sjdiscounttools.com/lis27490.html
For the rotor it's a small torx, I think T-8.
If it's a 1st-gen opti, then if you want to seal it, you should vent it, so any moisture that does get in has a way out. If it's a 2nd-gen opti, then seal away.
thanks again for all the info, i think i will practive with one of my crap optis and play around justt to make sure i dont screw my good one up, i tend to screw stuff up.
