HP on stock bottom end
Guys with stock bottom ends, what are your HP and Mods. Im lookin to see what the max I can push the LT1 to without a rebuild. Example, Simple bolt ons, Heads, Cam, anything on a stock bottom end. Id like to see around 400rwhp, show me what your runnin! Thanks
One guy here (in the NW) has been running with 400+ rwhp on a factory bottom-end for the past year... through an automatic.
Daily driven and track duty in the summer.
From a durability standpoint, he probably won't get 200,000 miles out of it of course, but that's the price you pay for playing on the wrong side of 6-grand. Personally my stock engine (CAI & air foil) put down 280rwhp through my 6-speed at 100,000 miles. Pushing 170,000 right now without problems. (factory optispark included ).
Oh yeah... almost forgot: that's 400rwhp NA, no boost or juice.
new injectors, heads, cam, PCM tune, of course... but nothing you need to pull the engine out of the engine bay for.
Don't even consider NA power levels like this on a 350 unless you have HUGE heads, a giant cam, and an amazing PCM tune. I belive he runs a 3500 stall.
I just put down 387rwhp with a base tune and 5 degrees of spark retard, and a small cam(~220/226) on stock bottem end through an automatic. With some more tuning it'll be at 400. Stock bottem end has 34k miles on it, gets daily driven 80 miles/day, and just netted me a 12.1 first time down the strip. Call up Lloyd Elliot and get your heads/cam and you'll be at 400rwhp no problem.
Location: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
450 rwhp with locked converter, 420 unlocked. All motor.
All the standard bolt-ons, hooker LTs, etc... ported factory LT1 heads (1.94/1.50), big hydraulic cam. Not a daily driver, but does drive VERY well on the street.
And that's a bone stock short block.
Steve...
Steve...
Steve...
Steve...
I've had 405rwhp on the stock bottom end for over a year now. Heads, big hydraulic cam, 11.9:1 compression and I drive it hard everyday except in the winter. I usually take it up to 6800rpm. Some people are lucky, others loose thier bottom end with just a cam.
