Hub Question
Hub Question
I spent so much time pulling this pain PITA off I didnt notice if there is a crank key for the hub.I noticed that there was a groove where the hub is.But I cant find the key if was there was one there.Shoebox diagram does not show it it detail.
Re: Hub Question
Per the shop manual and considering your circumstance...
Get the #1 cylinder to top dead center. Align the cast arrow on your hub to 12 o'clock and install.
The manual perscribes aligning the "dots" on the crank & cam gears (equivalent to #1 TDC) and installing the hub with the arrow straight up.
Even if you are off a bit it shouldn't upset the balance.
stockssn2o
05-25-2015 08:54 AM
mschmidt33
03-15-2015 07:20 PM
cyteone
02-07-2015 06:04 PM
