Hub removal/installation
I am going to install a new cam this winter and was wondering if someone on here has the Kent Moore hub tool that I could rent from them. Or if there is just a standard 3 hole puller from the parts store I could use. Also, if anyone one has the crane dual valvespring tool to rent, I would really appreciate it. Thanks
Re: Hub removal/installation
You can rent the tool for the valve springs from autozone or advance, both of which require you pay the cost of the tool which you get back upon returning it.
cyteone
02-07-2015 06:04 PM
