HUGE 383 problems!! Please help.
#17
I had the same problems after my cam and TC install. I didnt have the noise you describe but my car didnt move much either. I drove it around the block and it didnt come out of second gear. Problem was solved by adding more fluid to the tranny. I thought I had enough but didnt. When you do TC changes that happens. Check the fluid again. Hope you fix it.
#19
i turned on the car today and i noticed the fuel pressure was a 80 psi. i tried adjusting the afpr and didnt want to go down. i dont smell any gas. pcm4less did my programming. is that too rich? could it be that?
Magenta_Hearts
03-29-2017 08:54 PM
10-31-2016 11:09 AM
12-17-2014 11:00 AM
