hurst shifter option
The GM optional Hurst shifter uses the stock shift lever, so if you have a big concentric rubber bushing in the lever, its a GM/Hurst. If you have an aftermarket Hurst shifter, it will have a flat mounting tab with two bolt holes, that only accepts the Hurst shift lever. The GM/Hurst top plate also is a little flimsier than the "real" Hurst.
cmsmith
09-14-2015 09:25 PM
cmsmith
08-20-2015 07:57 PM
08-07-2015 01:26 PM
detroitmuscle
07-31-2015 04:21 AM
