Hypertech Programer
I used the hypertech power programmer on my 95Z and got great gains. In combination with the 160 thermostat from hypertech, the programmer took 6 to 8 tenths of my 1/4 mile, make the car shift stiff and hard to where you get knocked back, all around better performance and they only run about 3-4 hundred. Highly suggest getting one, plus you hve the option to change shift points, speedo calibration on the spot, and much more to account for tire size etc.
Don't know what kinda mods you have... but if you are spraying the car, don't use the "Hypertech Engine Tuning." It messes with your timing... that's only if you are spraying, if not have at it.
I love my hypertech. I need to get to the track with it.
Waste of money, do a search, this has been discussed many times. If you want tuning, get some real tuning from a mail order place (I recommend Madwolf) or fine a local area tuning. I've been tuning PCMs for a while now, and all the HPP does is change shift points, increase trans pressure (actually a bad thing when using the PCM, will cause premature tranny failure) and adjust the fan temperature. Any mail order tuner will charge about $50 to do this, $100 at the most. For the $350 you can buy a used laptop, the ALDL to serial interface cable, and Tunercat with LT1 FLASH def file and tune the car yourself. Don't waste your money on an HPP.
HUUUUUUGE Wast of money
I had the Hypercrap for about two months before I switched to a custom tuning. For HALF the price of the Hypertech, u can get a mail order tune, like pcmforless, madwolf, Ed Wright, etc. A home tune will also give u a better power increase as well as better driveability over a Hypertech.
MY hypertech with a custom supercharger program works great. I really can't say much about the mail order type of tunes, because I have heard both good and bad about them. Almost as much as the hypertech. Just in my case the thing works great. I have asked before about guys that have said negitave things about the hypertech in supercharger applications, and I never got any response about the actual hands on experance only second hand knowledge and the such. (This is in reguards to custom SUPERCharger programming not "stock" programming). So for me with a car that is not heavly modded (I only have a "stock" rebuild, headers, exhaust, supercharger) the programmer has worked great, But if I were to get heavly into the motor ie stroked, NOS, bigger blower, cam etc, then I would look into other computer programmers, but as I said in the past nothing beats a good dyno tune. Good luck.
I've got one. They are pretty much worthless for a manual, unless your car is under warranty. If u have a tuned pcm and u take it in for service, say goodbye warranty. The shift points for the automatic part is the best overall. Don't use the shift firmness feature, that builds up line pressure and kills your tranny. I dropped .3 in the quarter just messing with shift points. I think i prolly could have knocked another .1 second but we left after that. Get a used one off ebay, dont pay full price for one. Just to let u know Ed wright tuning costs $500 and most other tunes cost just as much as u could get a programmer for on ebay or more. However, dyno tune is the best, but also quite costly (hence ed wright tuning). I also like it for its adjustability. you can change whatever u want whenever u want too. -Michael
I had one back when I was starting out racing with light mods. Accounting for weather and track conditions I consistently ran slower with the power programming loaded than with the stock program.
To begin with, you don't need tuning unless you are getting a cam. You might realize some small gains with tuning the A/F with no mods, however, when you consider the cost/hp ratio, you are spending too much for too little.
If you are stock, and you can get a hypertech for next to nada, then you can use it to program your fans for a 160 stat, and your shift points on an A-4, but forget about A/F.
If stock, use your money for CAI w/perf. filter, etc.
If cam, etc. get a Mail-order (dyno, better yet). Oh. And if you buy one on the cheap from someone, esp. E-Bay, beware if they fail to deprogram their PCM before they sell it, because it only works on one vehicle at a time.
$80 NOT worth 13-15 RWHP and 13-17 RWTQ? I think it's worth every penny of it, but then again, that's just my personal opinion.
Plus, there's a lot of other things you can tune at the same time. (like fans, skip shift, etc)
I beg to AGREE with your disagreement. I DO believe that you can realize gains from tuning, even on a stocker.
Just saying that, you might as well wait until you get a cam, etc. if you don't even have a CAI, since it is one of those mods you'd want anyway.
I believe that since factory tuning is on the conservative side that there are usually good gains from A-Market tuning. The amount of gains, however, will be based on other mods.
If, however (and I don't dipute this) you can get a consistant 10-12 RWHP increase by simply leaning out a stock PCM, and the price is right, by all means go for it.
