Hypertech Thermostat
Hey everyone, i just bought the hypertech 160 degree thermostat for my 95 z28 m6 and it only cost 16.46 is that a good deal?? how hard is to install on my car because i have to drain some coolant to do it right? also did any of yours come wiht the rubber gasket that seats with the thermostat in the hypertech box. i didnt get a chance to ask the guy if it came with one or not. thanks guys and i will probably replacing my low coolant sensor also when i go to put my thermostat in. i still have to buy one gmpartsdirect is the cheapest place i have found but have any of you guys fuond it or bought it cheaper and for how much gmpartsdirect.com has it for 32 i think shipped or so!
You paid a fair price.
Thermostat change. If you will be doing your low coolant sensor, you will need to drain some coolant.
The new thermostat should come with the rubber o-ring gasket attached.
Gmpartsdirect price may be ok if they are not soaking you on shipping. I prefer to buy from Jason or Dal.
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #)
email: gmparts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
Shoe box- how much would dal and jason sell me the part for. how much would it cost to ship i think its 8 or 12 bucks from gm partsdirect i have to check again. oh also one more question i have to use the rtv high temp gasket maker sealant on it also right?
No gasket sealer is used on the thermostat housing. Just the o-ring.
I never thought that I would disagree with Shoebox.......BUT... and remember Shoebox has a plethra of knowledge and has helped me out several times........ As far as not needing gasket material on your thermostat housing and just using the o-ring gasket....this game me problems.....I didn't use gasket material and it leaked.....I put a small amount of gasket material on it and it fixed my problem.....But, don't put to much on it. Just enough to give you the extra peace of mind...... Not sure why mine didn't work right with just the o-ring gasket but the gasket material fixed it up........
You might also get by with just cleaning the low coolant sensor. I was told its just a float level type sensor that gets gummed up and can be taken out and cleaned. I haven't confirmed this yet cause I really dont wanna drain the radiator till I have to. Might save a 32 dollars if it works out ok. I will continue to live with my red light in the dash on.
Well ima still clean the old one when i take it off but i want to be sure that it will still be good so im just gon to spend 33 bucks to get one. so then it will be new and hopefuly i wont have to worry about it anytime soon! so how long has yours been on? mine came on about a month ago and thought my motor was overheating and comes to find out its fine and plenty of coolant!
Mine came with the Oring.... Thats the only gasket I needed, It has never leaked... ever. Cleaning the Coolant level sensor only ruined it.. no its not the lever type....it has one inmovable metal part that senses the coolant level and once I cleaned it .... it stopped working. Yeah I ruined it.
Change your coolant.... its only like 7 dollars for the gallon.... cheap cheap cheap.
Marvin
Marvin
I was getting ready to change the spark plugs last night and noticed some antifreeze on the front edge of my thermostat housing and a little on top of the water pump. I am assuming the thermostat housing is leaking, is this common on LT1's? Car has 103k miles. Thanks.
I will definitely check the hose, but is it possible that the previous owner over torqued the housing and that crushed the O-ring, causing it to leak? The bolts are real tight, definitely tighter than inch pounds.
Marvin
Marvin
As for EaC95Z28's question about how long its been on. It started coming on about 4 or 5 months ago. Had me really freaked out the first time it did it. But after seeing I still had plenty of coolant and the lines were in fact bled, I figured the sensor was bad. After reading a lot of the posts on this board, I realized I was right. I'll fix it someday, I promise
