I can see spark, pics inside
I can see a spark, seemingly random but frequent at idle. I'm not sure if you'll even be able to identify what you're looking at in these pictures but here goes.. I'm not exactly sure if I'm seeing a spark, but its blue and its in a cm or two long line, not like an actual spark. Here are pictures of where it is sparking or should i say "illuminating"...
http://www.geocities.com/elteewun/index.html
Incase its confusing the part im pointing to is not the maf electrical connector, i just got crappy angles, sorry
Is this unusual?
Is this unusual?
Hard to see in the pic's, but it looks to me like it is coming from yourr coil to ground, right next to you ing. control module ???
Try changing your coil wire, looks like your getting a arch from the coil to ground ????
John
Gator Transmission
John
Gator Transmission
Originally posted by Pro/Street SS
Hard to see in the pic's, but it looks to me like it is coming from your coil to ground, right next to you ing. control module ???
John
Gator Transmission
John
Gator Transmission
grabbem88
03-18-2015 01:25 PM
cmsmith
03-16-2015 02:34 PM
