i dont think i can use the cam i just bought
i just bought a cam and everything i needed from a board member.
and i was looking at the spec card and my god this is a big cam.
heres the card of the one i just bought
and heres the one we all know as the 306
now my concern is...i dont even know if this cam will work in my car look at the duration @.050 its 260. the other 306 that we all know is 230.
and what is the differnece in the 106 and 108 ICL how does this affect the cam. and the advertised duration is 306 int and 306 exh on the one i bought. and 290int and 307 exh on the other. what makes the @.05 duration change so much, is it the shape of the lobes or what.
i mean will this cam even run in my
does anybody have any insight as to how this cam will act.
eventually it will have heads and lt.
but im just curious will it even run on stock heads at all.
oh what have i done.
fred kmook any insight.
well the compomp cams site said it fits a engine from 57 to 97
so your saying it may not have the whole for a vented opti but would it fit a unvented like say a. 94 if so i could go back and put a non vented in.
im goging to call comp tommorow ask ask them will it fit. if not what would it take to make it fit.
well the guy told me that it would run the opti and the water pump. but i dont know which opti vent or non. thats just what he told me.
but if it does work how will it run thats my concern now. becuase he says it will work. i guees ill have to pull the in out of the stock cam and use it right.
Originally posted by rskrause
It's a solid roller cam and it's not for an LT1.
Rich Krause
Rich Krause
please bare with me. im just trying to learn.
i dont mind all the extra work it takes. but the stuff im buying from the guy is the lifters, springs, locke, retainers and of vcorse the cam. and he got it all as a kit from comp. doesnt come with push rods though.
i didnt plan on converting, but hey why not.
next year probably summer ill do a 383. not that it matters as of now.
I doubt you will be happy with it with stock heads and no headers. Solid rollers are most apt to be designed to run high rpms to make their power. Your heads and exhaust will be a bottle neck. It will also take some serious tuning to make it driveable. It probably won't run as mean as it is going to sound.
first off i would like to thank you shoebox for all the help you have givin me since i become a member on this board.
i do plan on putting ported heads and lts by tghe end of the year and it will be in a m6 so that may help drivablity. i just hope i can make it work.
yes but it will make good power under the curve, im told
and im not looking for a reall high hp. im looking for a great sound and alot of performance. but next summer its going into a 383.
if i dont like ill take it out.
