I need advice on engine rebuild
Old 06-03-2010, 08:17 PM
Larsv8's Avatar
Hello all,
I tore my car down this past weekend for a LE2 swap but found a chipped cam bearing. I decided to yank the engine and do a bottom end rebuild so I can keep it running for the long term.
I don't know very much about a how to pick a good combination of parts, so hopefully I can get some input from the board. The car will be a weekend cruiser, maybe less than a 1000 miles a year. I have all the supporting parts for the top end kit.
After doing some research, I was thinking of using this kit if the machinist says my stock crank is still good:
Ai Budget 355cid LT1 Rotating Assembly Package:
Utilizes Stock 3.48" Stroke Crankshaft (Not Included!)
Compstar Forged 4340 H-Beam Rods
Mahle Forged Pistons (-5cc)
Mahle Plasma-Moly 1.5/1.5/3mm Ring Package
Mahle Steel Pins & Wire Locks
$1195* - Your local machinist will need to add their preferred bearings & balance your crankshaft to the new reciprocating assy.
or this one if the crank is shot:
Ai Forged 383cid LT1 Rotating Assembly Package:
Compstar Forged 4340 3.75" Stroke Crankshaft
Mahle Forged Pistons (-16cc)
Main and Rod Bearings Included
Internally Pre-Balanced by Callies/CompStar!
$2196 - Ready for Assembly by your local machinist.
I just had a couple questions:
1.) Is this a good plan?
2.) Whats the typical machine costs to get something like this done?
3.) Are the only differences between the two kits the pistons and crank?
Thanks in advance!
Larsv8 is offline
Old 06-03-2010, 08:23 PM
charliediss's Avatar
Sounds reasonable, I am finishing up a build on a 97 LT1, 1400 for a stock short block and then another 600 for the top end and final assembly. I would expect the extra cost you are running into to be from the upgraded parts. Good luck.
Charlie
charliediss is offline
Old 06-03-2010, 08:37 PM
Kevin Blown 95 TA's Avatar
The 383 kit is also internally balanced so theres a few hundred for that and it includes the bearings.
Kevin Blown 95 TA is offline
Old 06-03-2010, 09:01 PM
Larsv8's Avatar
Charlie
You had 2g cost just in machine work?
Larsv8 is offline
Old 06-04-2010, 12:08 AM
Moderator
rskrause's Avatar
Those are good parts. The price is reasonable. Usually better to buy it all together as a balanced "kit".
Rich
rskrause is offline
Old 06-04-2010, 08:50 PM
Larsv8's Avatar
Originally Posted by Larsv8
Hello all,
Thanks in advance!
Anyone have any input on these two questions?
Larsv8 is offline
Old 06-05-2010, 12:01 AM
slomarao's Avatar
Machine costs could be anywhere from 500-1500 depending on how good of a job they do/how pricey the shop is.
Get a few quotes, see if you can take look around a shop. typically you want a very clean shop.
The 2nd kit is a 383, the pistons are a different cc and the it comes with a crank.
You could get a kit from summit racing for 650, it only comes with forged pistons and rings, bearings, etc. You would re use your stock rods and crank, put ARP bolts into the rods for some more strength. This will be a cheaper route, it wont be as strong tho....
how much power do you want? Just heads and cam??? do the summit route than.
slomarao is offline
Old 06-05-2010, 02:52 AM
Larsv8's Avatar
A specific power goal isnt really a priority, I just want to spend my money effeciently...best bang for my buck.
As long as it can handle the LE2 package, I am happy.
Larsv8 is offline
Old 06-10-2010, 11:53 AM
Cut out all the guess work and buy a short block from Golen...I hear nothing and have seen nothing but great things from them.
Old 06-10-2010, 11:55 AM
No, thats inspection (mic the crank and cam), machine work (including torque plate hone, build and final assembly.
Old 06-10-2010, 01:33 PM
lt1andy's Avatar
I sent you a PM
lt1andy is offline
Old 06-10-2010, 02:03 PM
http://www.golenengineservice.com/ht...4.html#LTshort
Old 06-10-2010, 07:58 PM
Larsv8's Avatar
Well I dropped the engine off at the machinist this morning.
At minimum he is going to hot tank it, dissassemble, check for problems, do bearings/plugs, reassemble, put all my new parts (heads/cam) on and paint. He quoted me 200 for that, which I thought was pretty reasonable.
If the crank is good but the pistons/rods are shaky I will go with the AI 355 kit.
If the crank is bad, I'll go with the 383 setup.
We'll see how it all turns out I guess. Thanks for info all
Larsv8 is offline
Old 06-11-2010, 06:03 PM
RamAir95TA's Avatar
A 383 and a 355 will respond better to valvetrain setups designed to maximize the displacement of each. What cam are you planning on running?
RamAir95TA is offline
Old 06-11-2010, 06:18 PM
You might want to "search" on "broken crank".
Injuneer is online now
Quick Reply: I need advice on engine rebuild
