I need exhuast sounds
Old 01-14-2003 | 04:20 PM
210Beast's Avatar
Can someone post a link to where I can get exhuast sounds for the SLP Loudmouth, B&B TriFlow, and the Borla. Thanks.
Old 01-14-2003 | 04:30 PM
1msfyter's Avatar
If you have DSL or cable I have a video I made 2 weeks ago.
My teal 95 has a loudmouth (LT1) My friends 02' LS1 has a LM also
the red 97 has a flowmaster. Should only take about 3 minutes to download
http://www.bealer.org/calidream.mpg
Old 01-14-2003 | 05:12 PM
210Beast's Avatar
Thanks for the vid! Damn I wish I was in Cali (its snowing here in Va )
A few questions (I read your sig):
How do you like the JET chip (is it stage I or II)?
Did you install the JET chip before or after your exhaust?
and
What is an LT4 Cam kit? Is it a good mod and what does it do? Where can I get it?
I have been looking into getting a JET chip, exhaust, and cam kit, among other things and have gotten mixed opinions about the Chip, and I would like to hear an opinion from someone who owns it. Thanks.
Old 01-14-2003 | 05:21 PM
1msfyter's Avatar
I need to update my profile. I got rid of the jet stage 2, went with PCM4less. I add LT4 exhaust manifolds(screw headers) too much work. The LT4 hotcam is just that , it converts your LT1 to an LT4. basically I added a larger cam, intake 52mm TB and I put in 1.6rr's. I spent too much of course . Ive now adding larger injectors and a torque converter. Dont waste your money on a Jet chip . Go with PCM4less! Ive put about $2500 so far in the moter Im always adding something
Old 01-14-2003 | 05:28 PM
210Beast's Avatar
Okay, sounds good then. Does the PCM4less also get rid of the speedlimiter?
Old 01-14-2003 | 06:30 PM
showtime89's Avatar
Here's a hooker supercomp if you are interested in video format:
http://users.adelphia.net/~showtime89/donuts.rm
or
http://users.adelphia.net/~showtime89/donuts.wmv
Old 01-14-2003 | 07:31 PM
CODY BEHNKE's Avatar
Off topic but, An LT4 cam does not make a LT1 into a LT4
Old 01-14-2003 | 07:39 PM
Rich_z28's Avatar
To convert an LT1 to an LT4 you have to go with the hot cam, LT4 Intake manifold, and LT4 heads.
Old 01-14-2003 | 08:32 PM
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Re: I need exhuast sounds
This is mine, With Mac Headers and off road pipe, and the smallest exhaust plate. This is a adjustable Borla Exhaust.
open blora
Old 01-27-2003 | 05:35 PM
kyzer soze's Avatar
or
Hey showtime your car sounds really good whats the difference between a hooker catback and your hooker supercomp catback? Is yours more expensive? Where did you get it?
thanks
kyzer soze
Old 01-27-2003 | 06:45 PM
EviLBoX's Avatar
I've got the sound files you're looking for on my webpage. It's in my sig.
Old 01-27-2003 | 07:34 PM
89irocz23's Avatar
I would think lt4 manifolds would be just as hard as headers would be.
94Maroz28
10-27-2015 04:38 PM
PopoFormula
10-12-2015 04:19 PM
4586
09-27-2015 01:55 PM
autoxr166
09-25-2015 04:21 PM
Ryan Ramsaran
09-19-2015 08:43 PM
Quick Reply: I need exhuast sounds
