I need help BIG TIME someone please respond back
I have a 1997 ss camaro... can somene tell me the the location of the
PCM FUSE on my car.....MY car wont start ive looked at everyone and it looks like my OPTI went out .... but i wanna make sure.... SOMEONE PLEASE RESPOND BACK !!!!!!!!!!!!!!!
All the lights come on , the car cranks over.....what happend was i put in a new sensor Crankshaft positino sensor the new one kept tripping a code for days... not this past wednesday the week before I almost made it home i was in my neighborhood and the car just died everything turned off.. Since then I had to get a new battery " cranking it alot killed it good thing it was under warranity, I replaced Crank shaft postion senser, check for fuel you can smell it , pulled cyclinder 1 spark plug there spark check all wires seems to be good, checked fuse box in engine and inside the car all good, pulled out the computer repluged it in... Honestly im 90 % OPTI butnot sure.. lights come on the car will crank over but wont start at all....
Ive had to replace the opti in my 94 but not this car im going insane................. advice and opinions are welcome
KEEP 1 THING IN MIND I DONT KNOW MUCH ABOUT WORKING ON THE CAR SO IF YOU DO HAVE AN IDEA PLEASE EXPLAIN IT AND HOW TO ATTEMPT TO FIX IT OR LOOK FOR IT THANKS I APPRECIATE IT
Did you have spark or not, i couldnt under stand what you were trying to say.
Just becasue you smell gas doesnt mean the presure is high enough to start the car. You need to go to the parts store and buy a fuel presure test gauge. You screw it in the shard valve (looks like the valve you put air in your tire with) that is located right behind your intake. Turn the car on and off a few times, and watch the gauge as you crank the car over. The gauge should be over like 38 lbs's
Time for a tow truck. Parts are expensive and replacing parts that are not bad will eat up your budget. Could be one of several things causing this, ignition module on the front of the engine maybe.
10-31-2016 11:09 AM
ChrisFrez
12-15-2014 03:09 PM
