I need some ARP part #'s...
I don't know the Chevy stuff too well yet (Ford guy ), so I want to make sure this stuff will work with the LT1, since a lot of stuff is "except LT1", you know what I mean?
Actually, let me ask "Where does the LT1 differ from regular 350's, in what will work and what won't?" What I mean is are pistons and bearings and bolts and studs the same?
Do I just get the "small chevy" stuff?
Anyhooter:
Main Studs: ARP-234-5501 (I saw a post on here that said they're too short?
Head Studs: ARP-134-4001
Rod Bolts: ARP-134-6403
Flywheel Bolts: ARP-200-2802
Camshaft Bolts: ARP-234-1001
Balancer Bolt: ARP-234-2501 (13/16") Do I need 5/8" hex or 13/16" hex, I forget?
Rocker Studs: ARP-134-7103
Does the "Engine bolt kit" have any value in this application?
http://store.summitracing.com/partde...P%2D534%2D9701
Something like that...
My rods are Scat 4340 forged I-beams with the SCAT bolts in them. What's the good replacement for those bolts? Is it going to be a problem going with different bolts since I've already had my rotating assembly balanced?
Anyhooter:
