A.I.R. Bracket Removable?
Re: A.I.R. Bracket Removable?
Yeah there should be a couple bolts holding it on. Here is a great website for AIR removal.
http://www.zmydust.com/airpump.html
There 2 bolts that I use for the AIR bracket, if your looking from the top of the engine bay you wont see it, just put your hand under the lip and you will feel it. Makes plug access easier.
After looking at the bracket and bolts a little longer, I have another question. Do any of these bolts pass through the water jacket of the block? I have the heads off and coolant drained so I woulnd't be able to tell until I put coolant back in. Just want to be sure.
rick350
03-14-2015 10:46 PM
SMO Q
02-11-2015 07:13 AM
squarehead
11-21-2014 08:02 PM
07-04-2005 05:00 PM
