A.I.R. check valves on exhaust manifolds...
Do I need them anymore?
Installing Pacesetter mid length headers and cannot remove check valves from old manifolds.
Dealer want $87 EACH.
It's a 94 and I don't need to go through emissions any more and the catcon is going away.
So. Can I just eliminate the check valves and air pump?
Re: A.I.R. check valves on exhaust manifolds...
Heat the manifold and metal secondary pipe with a torch; usually loosens it enough where you can get it off. They also show up on ebay pretty often if you look at LT1 if you want to keep the emissions, no cat does smell quite a bit more.
07-04-2005 05:00 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
SilverWS6
13
08-14-2002 09:29 PM
newby
10
07-27-2002 11:39 AM
