I think i found the limit of a stock rotating assm.
#16
well i found out today that i didn't lose the bottoem end. When we started the eingine for the fist time in the begining of the week we heard a slight chatter.. thought it to be a little loose rocker or something.. I have open long tubes also so you can't hear much of anything.. Well when i pulled the heads off today, every single cylinder had a butt load of metal chunks in them. I found an exausht valve on teh number 3 cylinder broken of and it looked like it was in there bouncing around for a good amount of time, long enought to almost wear a whole through the piston, and make enought metal shavings to get into every last cylinder. They were in the intake also.. So my guess is the valve broke and with how loud the car is we didnt really hear it that well.. Then on the one rev the piston smashed teh valve into the head and couldn't finish the rest of the movement hense the reason i couldn't turn it over. with the heads off the engine spins quite nicley. a few of the cylindes were filled with oil also. So i am just buying a stock long block and going from there. I wish i knew what caused the valve to break.
#20
Originally posted by Dr.Mudge
Sucks to lose an engine, I toasted my 69 Firebird 400 years ago, likewise not exactly doing "smart" things with it. I believe I ended up in oil starvation land (constant high revs), and lost 3 rods, at least one bolt (? it was a small hole, maybe just a rod gouge) I believe shot out of the oil pan emptying it. When it went it was instantaneous, whatever it was, cast iron and aluminum bits under the intake, not pretty.
Ben
#22
Originally posted by Momar
Unfortunately I have heard that is a comon problem with the pontiac motors.
If your valve springs are weaker than they should be (incorrect spring height, or old) then they will not be able to close fast enough, this is the valve float you experienced.
For valve springs that are marginal for the cam/rocker ratio they are setup with, you unfortunately have to be carefull with RPM and they should be repalced more often than if you had a bit more headroom with the springs. If you have .595 lift on the exaust and .600 lift springs, thats not alot of safety margin.
#23
All I know, is with a TH400 and who knows what rear gear (2.73?) 130 MPH to work every day was pushing my luck, and my luck ran out after awhile. It was 3am so I saw no more than 3-4 cars on the way there, for those who would like to chap my hide.
Ben
#24
Would it be the vibration that causes damage when you rev in neutral? Strange side note. I have a 90 jeep 4.0L that gets rough if you go above 3000rpm in any gear if you're at part throtle. But it is smoth all the way to 5500 if the pedal is to the floor, and the engine is under a heavy load. Maybe it just the 150,000 miles.
#25
My gut feeling says the crank is going to look ugly when not under a load and revving high, I think maybe a form of crank float along the bearings and oscillation from front/rear, but who knows. If thats true though that would account for an effect like rod stretch, which could also punch a piston.
If valve springs are 150k miles old, they will not take high RPM safely, and these things can happen, and do. This happened to one of my dads cars about 10 years ago, that at the time was about 15 years old. One valve hit a piston and punched a whole in the piston and broke the valve.
#26
I hope my vlave springs aren't to weak.. They are the crane cams dual spring.. i can't remeber the part number but there supposed to be good up to .600 lift and i only have maybe at tops 7-800 miles on them.
#27
Here are a few pics of some stuff that went wrong. Just click the link that says broken parts. http://www.angelfire.com/freak2/crawlinz/index.html
#28
I've spun my stock shortblock to 7200 a couple times under load.
Not under load....dunno, 6500 I guess. With a stick car, when running N/A when you don't have enough gearing (car is set up to run best on the spray, not N/A), you gotta rev her pretty high when you drop the clutch to get out of the hole well. When I was internally stock, I'd do 6000RPM WOT clutch dumps off of the MSD rev limiter; THAT was fun.
HuJass
18
06-24-2002 09:19 PM
