i want a lopey idle
i want a lopey idle
i have a 93z with a 6speed
I am going to be buying a cam springs and 1.6 Roller Rockers.
All i have done is hooker long tubes with true duals.
I want a lopey idle but good streetability. What cam would you guys recomend.
I dont have any complants with the 224/230 here is what my car sounds like with longtubes&borla "wide open plate"video
:EDIT: Madz28.com will burn you a chip for it too.
having a lower lsa(112 and down) will make your idle lope hard. The actual cam you get you may want to look into more. The cc305 and xe224/230 and two milder cams but they should net you a 40hp gain with tuning. They would both be good choices if you don't plan on heads. Look into peoples signtures and check out their dyno numbers and et.'s you'll figure out what you want pretty quick. Good luck
autoxr166
09-25-2015 04:21 PM
