IAC loudest part of engine! HELP!!
OK, think I finally got my miss/stutter issue solved, but before I put it all back together and drive it...
I fired it up straight open TB (no elbow etc) and the IAC is the loudest part of the engine! You can hear it sucking air over the LTs/Mufflex 4"!!!
When I plug the hole in the bottom of the TB (to the IAC valve) it runs great, and has a nice smooth, low idle. Before I was having erratic idle issues also.
Replace the IAC? What happens if I just plug it off? Or unplug the IAC altogether?
THANKS!!
THANKS!!
Re: IAC loudest part of engine! HELP!!
update, just unplugged the IAC motor, and it seemed to have no effecton anything, still hissing and sucking, and drowning out everything!
If I replace the IAC motor, sill this be solved? Where do I get one beside the dealer, AZ doesn't list one?
you didnt just put a new throttle body on it did you?
the bbk/edelbrock ones whistle pretty bad, at least the old ones do.
my car use to sound like it had a blower.
Originally Posted by 30th TA 0219
it does have a BBK 58 on it, but I mean this thing sound like a jet engine, and if I put my finger in it, it idles 100000% smoother!
its might not even be the iac, i smoothed out the hole for the iac and it made mine alot quieter.
oldschool
02-09-2016 09:21 PM
