icm a ground?
icm a ground?
my 95 camaro z28 6-speed want start. i replaced plugs/wires and optispark. still no start. i got to looking at the icm.
is the back of the icm a ground to the head?
thanks Dustyn
thanks Dustyn
Re: icm a ground?
The ICM is mounted to a heat sink that is mounted to a plate that is mounted to the front of the cylinder head.
http://shbox.com/coil/coil.html
The ICM must remain cool to operate. Most auto parts stores can test it.
If you are getting no spark, you may want to do this test, too:
http://shbox.com/1/4th_gen_tech2.html#opti_test
Re: icm a ground?
Only if its causing the ICM to overheat. The "heat sink" is the metal base. The heat transfer compound goes between the module and the metal base, to help pull the heat out of the ICM. But it can still overheat even if installed correctly. That's why Shoebox has a page that explains how to space the ICM bracket off the head, to reduce heat soak.
Problems with the ICM, including shorts and grounded circuits will show up as trouble codes. Have you scanned it for codes?
Nayr
03-03-2023 08:34 PM
autoxr166
09-25-2015 04:21 PM
Ryan Ramsaran
09-19-2015 08:43 PM
