Ignition Control module
I was wondering for the LT1 i heard there was an ingnition control module fix for heat....my car is having the not starting sympton after its been hot. After it cools off it does start and ive checked everything in the fuel system is working blah blah done a scan nothing. So i am pretty sure its the ignition control module now. If you could give me any tips on a good one that would be awsome....there are 2 offered from summit dyno something and stock. Also looking into a new hypertech coil with this combo....the one thats over 54000k volts. :Chris
Re: Ignition Control module
The ICM Cooling Mod links below worked just fine for me.
(Courtesy of Shoebox)
ICM Cooling Mod
http://shbox.com/1/ICM_air_gap.jpg
ICM Cooling Mod
