Ignition going??? HELP!
1. When I turn the ignition for the first time, nothing...Guages and sensors are fine, as well as battery(and terminals are clean). The second time I turn the ignition, it cranks and starts fine.
2. Sometimes when I give the car a little gas in a low gear at low RPM the car hesitates a bit, almost like a cylinder didn't fire...
Anyone have these problems??
One thing, I haven't had my injectors flushed in a long time and since I moved from Toronto to Cali, my car hasn't been running that good. I think it could be that MTBE gas...
