Ignition Problem help me
Old 04-19-2010, 07:06 PM
sburnsy's Avatar
Hey I have a 95 z28 and I am having a misfire on cylinder 2 and 7. I have replaced the opti, harness, coil, plugs ,and wires and am still having the same problem. Also checked the injectors and they are working.
sburnsy is offline
Old 04-19-2010, 07:09 PM
95zsean's Avatar
Bad Opti?
95zsean is offline
Old 04-19-2010, 07:33 PM
sburnsy's Avatar
idk this is the second opti and they were both delphis so i dont see how they both would have the same problem
sburnsy is offline
Old 04-19-2010, 07:36 PM
dangalla's Avatar
any codes?
list them all please
and some more information about your car and what you have done to it would help as well, maybe put that information in your sig so you dont have to list it every time you ask a question
dangalla is offline
Old 04-19-2010, 07:50 PM
sburnsy's Avatar
well the light isnt on and its a 95 6 speed all stock for the most part when i put the first opti in it ran great for a few miles then started missing. It wasnt sending spark to 2 or 7 so i warrantied it and just put the new opti in and it has same problem.
sburnsy is offline
Old 04-19-2010, 08:03 PM
dangalla's Avatar
where are you getting your opti's from?
no codes at all though?
did you change the cap and rotor also?
and again, information about the car and any modifications would be awesome, but thats only if you want us to help
dangalla is offline
Old 04-19-2010, 08:11 PM
sburnsy's Avatar
im getting my optis from rockauto.com i got the delphi and its not putting the engine light on but i cant check the codes bc i dont have obd1 scan tool. The car is all stock no aftermarket mods except for msd coil.
sburnsy is offline
Old 04-19-2010, 08:14 PM
dangalla's Avatar
dangalla is offline
sburnsy's Avatar
and no i didnt change the cap and rotor i just got a whole new unit
sburnsy is offline
Old 04-20-2010, 04:34 AM
Guest
Guest47904's Avatar
Have you checked the compression of at least those 2 cylinders? The right way?
Guest47904 is offline
Old 04-20-2010, 05:12 AM
The codes for the Opti optical sensor do not turn on the SES light. You have to scan it.
Injuneer is online now
Old 04-20-2010, 06:08 AM
sburnsy's Avatar
i didnt get to check compression yet and i will see what i can do about getting a scan tool thanx for the help
sburnsy is offline
Old 04-20-2010, 09:28 AM
95Blackhawk's Avatar
How do you know those cylinders are missing?
95Blackhawk is offline
Old 04-20-2010, 07:10 PM
sburnsy's Avatar
i pulled the injector connectors and listen to the idle
sburnsy is offline
Old 04-25-2010, 11:17 AM
sburnsy's Avatar
ok so i spark tested it and its not sending spark to cyl 2 and 7 but the other opti did the same thing so i doubt 2 different optis have the exact same problem so im guessing the pcm. any thoughts?
sburnsy is offline
Quick Reply: Ignition Problem help me
