Ignition Switch or the key lock and tumble??
Old 01-10-2005 | 12:20 PM
BigTedz28's Avatar
Ive been having a slight problem the last few days, and it seems to me like the ignition doesnt want to stay in the on, position for my fuel pump to turn on, but soon as i turn it a lil bit more, all my lights starts to come on my dash board and all, as soon as i start my car, if i let the key go, it goes off, if i hold the key a bit, it will stay on, but only with my help.....?? is this the iginition switch .......or my lock and turn ign, hole......???
Old 01-10-2005 | 12:23 PM
med_reject's Avatar
Re: Ignition Switch or the key lock and tumble??
when that happened to me, it was the ignition switch. I didnt have issues with my lights, but when i let the key go back, the car would shut off. If i gave it some gas and fiddled with the key, i could get it to run eventually.
I replaced the key lock and cylinder and that did nothing.
Old 01-10-2005 | 12:26 PM
LT4383's Avatar
Sounds like the ignition switch to me. You may be able to get a way with adjusting it. Very easy to replace though.
Old 01-10-2005 | 03:11 PM
BigTedz28's Avatar
???????very easy to do huh?????????????
hmm well can y0ou give me a website so i can follow it for steps ....? thanx
Old 01-10-2005 | 03:44 PM
Sure, mine. I would not categorize it as very easy, but it's not very hard.
You might want to try moving the tumbler around while you have the rod disconnected from the switch, just to try and make sure you don't have an issue with that part of it.
Old 01-10-2005 | 03:45 PM
'94 Bad A Z28's Avatar
Deffinately the ignition switch.
Heathen1
01-02-2016 04:27 PM
robcarnut
03-20-2015 03:40 PM
Dzmaro
01-25-2015 10:39 AM
Quick Reply: Ignition Switch or the key lock and tumble??
