Im getting spark and fuel...what gives??
So i've been trying to diagnose whats wrong with my car, its been down for a month now. It all started when I came home from work and I spun through some sprinklers all of a sudden my car started backfiring and if I gave it gas i got nothing, it coasted to a stop and wouldnt start back up. The car ran fine before that. So far i've tested to see if the injectors are working and the spark from the spark plugs/coil. Both are getting spark and my injectors prime everytime. I've tried new plugs and new coil and both didn't work. I've been waiting for a friend to bring a tech2 but he's been busy. Im not sure what else to do, I tried to do what shoebox says to test the opti, but i didnt have a digital voltmeter - just a ghetto one.
Correct me if im wrong (im not sure exactly how the opti works) but if the opti were the cause I wouldn't be getting spark at the coil or plugs would I? Even with a spark plug in the boot and a crank of the engine I get plenty of spark but it wont turn over, all i get is a couple sputters like it wants to start but no fire. I've checked all fuses and relays.
What else can I try or do without a scanner?
i believe you'd still get spark, but it just wouldnt be too strong..thats what happend when we tested an opti that was going out
With the spark plug out, did you verify that the plug was sparking as the cylinder was at TDC? This would be the point when the open cylinder is finished letting all the compression out of the spark plug hole.
How have you verified this? Have you checked (with a Noid light) to see if they are pulsing as the car is cranking? How does your fuel pressure look?
I checked the injectors with a noid light and they were pulsing as it was cranking. I havent checked FP with a guage but I just got done getting my 383 tuned and have never had FP problems - if anything, my FP would be high - its been tuned down pretty far.
I've only put maybe 8,000 miles on this engine. I replaced practically everything except the opti, rear end, and tranny.
Just because you haven't had FP problems, doesn't mean you shouldn't check it. FYI, you can't tune FP; you can't adjust it unless you have an afpr. If it's cranking and sputtering, sounds like a fuel problem. That's why I asked.
I have an aeromotive FPR and its been adjusted accordingly. This sputtering i speak off is not even remotely sounding like the car is wanting to start, more like the motion of the crank fliping over once or twice. Why would my car backfire before it died if I was loosing FP? The car ran perfect up until that momment.
