Injector questions
Injector questions
well I have a 1994 camaro lt1, 6 speed and i have a set of 36lb injectors (i know i dont need that big of injectors) but I got them for free....
I havent put them in because I wasnt sure if i needed to have my pcm programmed for them? or will the computer be able to figure it out?
Re: Injector questions
I think your definitely going to need a tune. I don't know for sure, but some times to large of injectors are not good. It doesn't operate in the efficiency range of the injectors if too large, but not sure what size is too big. Any mods?
Assuming your car is stock, since you have no info on that. I think the stock injectors are good into the higher 300 hp area or higher. It would be a waste of time to pay for a new tune at this point. Plus the car will not benefit or increase the performance with bigger ones.
As the others have said....no need to put them in on a stock LT1. Just hold on to them for future engine upgrades(cam, heads, or increase in displacement...or a combination of the mentioned).
sry forgot to put that in...I have headers,exhaust with no converter, a 58mm tb .... i was just woundering because these injectors came off the car (blown engine) i got the headers and exhaust off of and these were the injectors in it and i pulled the tb, intake and heads off and it was all stock.... i was going to send my computer in to pcmforless anyways to change a few things anyways,so would they be too big even if i had my car tuned for them?
When you put 36 #/HR injectors in a basically stock engine, the fuel demand will not suddenly increase, so the stock pump will be more than adequate. The fuel demand remains the same. The PCM just reduces injector pulse width, to deliver the same amount of fuel in a shorter period of time.
07-04-2005 05:00 PM
