When replacing injectors, do I have to relieve fuel
pressure ? If the car is not driven for a few days,
will the pressure go down, so I don't have to do it ?
after a few days the fuel pressure will go down, but as a good measure you should open your gas cap and relive any pressure from the schrader valve on the fuel rail. Good lUCk!
