inline fuse on 12V+wire for aftermarket guages?
My fuel pressure guage said to put a 1 amp fuse in the 12V+ wire. However, I have my fuel pressure, boost, wideband A/F, and cutout all wired to the same 12V+ wire going to the fuse panel. This will blow the 1 amp fuse in no time. What size fuse should I go with since these are all tied together? Thanks
Re: inline fuse on 12V+wire for aftermarket guages?
The heater in a wideband 02 sensor will draw around 2amps max. Why can't you come out of the fuse panel, into all the other gauges, then off that junction into the fuse and fuel pressure gauge?
i currently have all 3 of the guages tied into the same 12V+wire right behind the guages. I could rewire all of it but it would take quite a bit of time. I was just curious if I could put a larger fuse in to accommodate multiple guages hooked up to the same 12+ wire.
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
CARiD
09-30-2015 05:44 AM
autoxr166
09-25-2015 04:21 PM
Ryan Ramsaran
09-19-2015 08:43 PM
