installed new starter??
Re: installed new starter??
well the one bolt where the postive cable the big one goes can only go one place. the small one i just put it on the bolt where the nut was set when i took it out of the box.. so you think its on there worng then- yes it just spins
thanks
thanks
If it only comes on when you turn the key, I would say something is wrong with the solenoid or bendix and you should take it back. The smaller purple wire should go to a terminal marked "S" (if so marked).
Oncomingstorm22
01-22-2015 07:15 PM
