installing SFC?
i rolled into the shop with the KBDD already bolted up, it took the guy a little over an hour to weld them up real good, i had mine done at the local exhaust shop for $15
i just showed him where to weld and he welded
jesse
jesse
Originally posted by PoorMan
I don't know if it REALLY matters but I have heard that it is best to half them welded with the suspension fully loaded. So a drive on lift is prefered.
Jeff D.
Jeff D.
It definately takes more than 20 minutes. I would say about an hour on average. My BMR tubular's took even longer than that, but we did the welding ourselves and were taking our time. You have to unbolt the rear control arm and bolt the SFC to that hole. Than you need to prep the surfaces for welding(grinding down to bare metal.) Then line them up. Then weld them. And yes, you want them on a level surface with the suspension loaded. Also, you will want to paint the area after it has been welded to keep rust from building up.
Dan
Dan
GA93FORMULA
07-24-2002 11:38 PM
