intake manifold bolt
Hey guys I was wondering I looked at the back of the in the intake manifold driver side I need to swap out the bolt that holds that Gray solenoid that's got the two vacuum hoses,because idiot mechanic didn't put that doubled side bolt to hold the solenoid correctly.
If I swapped the bolts out will that ruin the intake manifold gasket or is it safe to swap thank you guys
94 Chevy camaro z28 pretty much stock
NewsBot
03-16-2015 01:51 PM
NewsBot
03-13-2015 08:15 AM
NewsBot
02-26-2015 03:10 PM
