Intake manifold to head port sealing question?
OK. I've seen a few threads lately about this subject. Apparently, many have issues with the intake gaskets not sealing if the heads and/or block have been cut. Is there any way to check this upon initial assembly? My block has been zero decked, but the heads have only a light cut on them. I'm using Cometic .036" head gaskets, and GM intake gaskets. The intake bolt holes all line up, and the end gaps look about normal.
Frank
CPT
Frank
CPT
The intake bolt holes lining up is a GOOD thing. To check it, take a pair of paper gaskets and using those, torque the manifold down. Then remove and check for a good pinch. It will be readily apparent if you're not getting a good pinch somewhere.
ModdedNerd
12-14-2014 10:28 AM
07-04-2005 05:00 PM
