Introducing our "old geezer" LT1 heads and cam package!
#31
Could you post up a flow sheet of one of the intake and exhaust ports for these heads, along with the criteria used to achieve those results?
#32
Now the biggest thing to keep in mind here is that a stock LT1 intake port measures 170cc..these heads end up in the 175-177cc range! so very little material is removed to get these numbers with the stock valves!
Old Geezer Heads
Intake / Exhaust
.100" 72.4 56.0
.200" 138.5 117.8
.300" 188.6 152.3
.400" 228.9 170.3
.500" 257.6 176.8
.550" 260.8 179.9
.600" 254.9 183.7
That is with stock valves, 4.030" bore fixture with a radius inlet and no pipe on the exhaust.
#34
We are going to test the cam with our stage 2 heads as well just to see what happens to low end tq production. I'm sure the power numbers will jump and peak tq as well, but low end might suffer. we'll see. Thanks for the kind words though.
oldschool
02-09-2016 09:21 PM
