Istalling heads and got oil on new 1074 gaskets
Hey all,
oil got on the gasket before I had a chance to tighten it down and it has soaked in but not all the way to the other side of the gasket.
Is this ok or should I use a new gasket now that I am ready to torque it down?
I've had friends at work clamp down a head with oil still leaking out of it and not have problems, but if it was me I'd probably use a new one unless it was terribly inconvenient. I don't even pull the gaskets out until I'm ready to set them on the block in order to avoid questions of "will this work or am I going to have to do it all over again?"
