Jet Hot LT question about O2 sensors
I don't need O2 bunges or air fittings or anything if I'm not worried about emissions do it? I want to eliminate all that crap basically. I plan on running an off road pipe with them so cat's won't be an issue. I figured if I had to I'd just install O2 sims. If I do get sims it doesn't matter where I put them right, just as long as they are tucked away somewhere and don't get the wires burned. I plan on getting a pcm tune and any of the useless crap that I don't need I'm gonna get tuned out. Thanks everyone.
if you have a 94-95......you need the O2's and extenders, but you can get rid of the EGR (you need a blockoff plate for this) and AIR stuff.
on a 96-97, you need O2 extenders for the front, and O2 sims for the rear. here is a great page that tells you all that you need, and how to do it.
Thanks for the help everyone. Cleared up my question. Making sure I have everything right. I have a 95' so I have to use the extenders and still use the front two O2 sensors. I shouldn't have rear O2 sensors so no need to use sims or anything with that right. Thanks again
07-04-2005 05:00 PM
