Just bought an B&M shiftplus electronic shift kit, doesnt work?
I just bought a B&M Shift Plus Electronic shift kit, its all hooked up,wires are correct and it doesnt seem to shift better at all. It still has the same Lazy shift. Does anyone know anything about these? or know what i might be doing wrong?
You might do a search. You will find many warnings about using a Shiftplus and what it might do to your tranny. If you have it connected properly it should work, unless the unit is bad. Double check your work. Use a meter or test light to verify connections, if necessary.
I installed the B&M Shiftplus kit on my 94Z a month ago and could'nt tell it was working due to the poor job it does at stiffening the shift. I thought it would be good to be able to turn off the stiffness, but I am very unhappy with the product.
