Just got back from the dyno
Well i just got back from the dyno and with the mods in my sig and at a 15.5 AFR i put down 281rwhp and 314 rwt
During one of the runs i had a fuel pressure gauge installed and at idle with vacuum it showed 38 psi and with no vacuum it showed 46 PSI
As soon as i started the run, the fuel pressure never even made it to 46 psi, it gradually went down during the run and ended up at 22 psi at redline
Time for a fuel pump, im hoping to be over 300 with proper fuel pressure and no doubt less timing being pulled due to running lean. Any estimates?
armedtrigger
02-24-2015 08:30 PM
