K-Member Not Dropping Enough
I'm trying to remove my oil pan. I have the motor mounts off the brackets a couple of inches, the motor lifted at the bellhousing, and the 6 bolts holding the k member are loosened all the way.
I can't seem to get enough clearance though to remove the oil pan. The pan is ready to fall out, all bolts removed, sensor off.
But the k member is in the way. How do I get the kmember to drop some more??
Take the bolts out for the shocks and it will drop a lil more..I left all the kmember bolts in but I was only using 2-3 threads to hold it...Taking the shock bolts out allowed me to drop it another 2 inches or so..
Cody
Cody
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
tdigger9899
09-07-2015 10:56 AM
