K&N cold air - cutting a whole worth it?
I just installed my new K&N cold on on my SS. Works great, I love it. And it cleans up my engine bay really well. (previously had the stock SS ram air box... old and cracked) So anyways.. I remember reading in a couple of different places that there is only something like 1.5 cubic feet of air in the fender wall. And that gets sucked up fairly quick. So would cutting a whole in the bottom of the fender be worth it at all? Thanks
Trevor
Trevor
Re: K&N cold air - cutting a whole worth it?
Trevor
Trevor
I don't want to just cut out a whole. I meant I wanted to make a scoop. Only problem is the air deflector is in the way. And before I just go slicing and dicing everything. I just wanted to make sure of any pro and cons.
Trevor
Trevor
I've done it to mine..........
I just chopped a hole in the black plastic under the filter and the front skirt.
I bought a sheet metal scoop, painted it black and placed it in with some screws.
The scoop gets damaged easily because its thin and rubs on large speed bumps and underground parkades.
No big deal really, it costs just over a dollar and is simple to replace.
As far as water getting in, just don't drive through rivers and such.
A mist from rain will not have a bad effect on anything.
This would be an example of too much water in the intake.
BTW: Nice link lol
I've had mine done for about 2 years. We have a good many rains here in the south and i've had no problems with water. Its just an opening with a scoop. The scoop doesnt actually connect to the filter or anything so you dont have to worry about water. As for is it worth it, Yes. I gained .1 and almost 1mph with it. Thats well worth it if you ask me. Besides its really a cheap project. Alot of guys just cut a U shape in the plastic and bend it down a little. Works probably just as well.
I took both my splashguards off years ago.
Its not my daily driver anymore but you should be able to drive in the rain without any problems.
Do not drive through standing water, of course I would not do this even if the splashguards were on.
It's not worth the risk in my opinion. The amount of extra air pulled in may be minimal.
Take a good look at where the air is drawn from and you will see all sorts of air passages to the filter.
Do all of you guys realize that just cutting the air box may actually draw air OUT of the air box. Air rushing past an opening causes a vacuum at that point. Unless you cut an opening that is facing the airflow, you may be doing more harm than good.
Unless you do the ram air method, this mode could hurt you. If you do the ram-air method, watch out for rain.
It's not worth it at all in my opinion.
Dan
Dan
The plastic were cutting isnt on the air box. Most of the people doing this mod have an aftermarket K&N CAI or some other brand. By no means will letting cool air to your filter gonna hurt your performance. Like I said above, I gained 1 tenth and 1 mph by putting this scoop and letting in much cooler air. Im not sure what it is but it was posted on this board somewhere. For every 10degree drop in air temperature your intake is taking in its like 3-5hp. More reason why I run .4 secs higher times in the summer rather than fall time. The temp outside makes a huge difference.
I'm not willing to take the risk of water damage. All it takes is one good puddle...
Dan
I don't get how a puddle can do anything at all. The ram air scoop is facing forward right behind the air damn. It would pass over the puddle, and then the first thing to hit the puddle is your left front tire. So then it splashis, no biggie seeing as the air scoop has already gone over the puddle, and is now facing forward therefore no opening to let the water in. The splash would have to move faster than the car to get ahead of the opening and then curve back in.
The only way I can see large amounts of water getting in, not mist, or a few rain drops.. thats no big deal.. but and actual wave of water into the fender, and then high enough to actual reach the filter itself, is if you dipped the entire front end of your car into a puddle. And honestly.. if the puddle is that big in the first place, who would drive throught it?
I think I'm gunna go ahead with this. I'm not putting a big honking scoop thats gunna stretch down to the ground. It's about 4.5 inches wide and 2.5 deep.
Trevor
Trevor
