Keyway on Crank - TDC??? Keyed Hub?
I know our cranks have a keyway and I was looking at getting a keyed hub they sell at Thunder Racing. My harmonic balacer has those balancing weights so it's very important that it goes with it pointing up at TDC. Now, is the crank keyway positioned at TDC? I don't think it is so I'm wondering if that will prevent my from using their keyed hubs.
I have a keyed hub. When I lined up the dot on the crank sprocket (of the ED timing set) in the 12 o'clock position the keyway was in about the 2 o'clock position. I don't know if this helps you through.
10-31-2016 11:09 AM
stockssn2o
05-25-2015 08:54 AM
cyteone
02-07-2015 06:04 PM
1fastformula
3rd Gen / L98 Engine Tech
06-19-2002 06:46 PM
