knock retard help
Run it with race gas to see if the knock goes away; if it doesn't then you've got false knock. Brett Fraker's website has a link to installing a knock desensitation circuit to help with false knock.
Originally posted by 818camaro95
What if it's real knock? What would be causing it?
Anyway, a knock will occour with a lean condition and/or excessive timing advance. Theoretically, if you have bad plugs/wires, or suffer from lean condition (fuel pump/filter/pressure regulator/injector failure) you could be detonating.
Good luck
