Knock Sensor replacement?
Here's a link for a coolant drain procedure (courtesy of Shoebox):
http://csce.uark.edu/~jgbertr/rb/4th....html#radflush
If you click on the "knock sensor" in yellow, it will take you to a picture of it.
Don't know if this helps any. I've removed mine several times (flushing the coolant) and there's nothing to it really. Should be straightforward.
