Kook's LT1 long tubes finally arrived!! Pics inside
Old 12-11-2004, 06:00 PM
  #31
madhatter's Avatar
Re: Kook's LT1 long tubes finally arrived!! Pics inside
Originally Posted by stereomandan
Nice headers.
Man those are going to run hot! No coating and they are larger than other headers, which means that they will be closer to other components in the car. Better have a plan to take care of the heat under the engine. I'll be interested to see if they make any more HP than other headers up to about 400 rwhp.
Dan
Stainless is just as effective as Jet-hot for taking away the heat.
madhatter is offline
Old 12-11-2004, 06:02 PM
  #32
Spinner's Avatar
No. Its not. Stainless doesnt transfer heat well throughout, BUT it will hold heat just like anything else. You cant really compare it to a heat reflective ceramic coating.
Spinner is offline
Old 12-11-2004, 10:21 PM
  #33
madhatter's Avatar
You smart-asses and your purple cars....
Old 12-11-2004, 10:28 PM
  #34
Spinner's Avatar
Least it doesnt have satin black front fascia highlights
Spinner is offline
Old 12-12-2004, 01:49 AM
  #35
Houdini's Avatar
I will add something.
I was told by Nick @ Kook's, that coating on stainless headers has no real benefit and has a tendency to come off at a much faster rate than mild steel headers. Is there any truth to this statement?
I would like to get my Kook's headers coated, but he advised otherwise.
Houdini is offline
Old 12-12-2004, 02:23 AM
  #36
bunker's Avatar
Depends on the steel, I had my SLP stainless headers coated, I belive they were 409 stainless? The coating stuck on there real good! It never even came close to comming off. However there was prolly more ferrous material in the SLP headers the kook's, aren't kook's 304 stainless?
bunker is offline
Old 12-12-2004, 03:10 AM
  #37
JWBerk94Z's Avatar
Originally Posted by Deenasty
thats weird I didnt have to jack my motor up to get them to go in, do you have the car high enough? I also had the same problem with the AIR fittings, but I just capped mine off..Call nick@ kooks ver nice fellow, he can help you out with any problems..
Hey Deenasty, how about some pics of these things installed. I saw another post where you had some links to pics, but they were dead. If you can email me some, I can probably put them up. Or if you could fix those links LOL. I really want LT's on my lowered car and I would love to see what type of clearance there is. You say you don't have any trouble on yours and I believe you, but I would still like to see them installed. I just keep thinking about my buddy's TA with Hookers and a mufflex y. Man, I can follow him and it looks like the dang exhaust is falling out from under the car. (it is still stock hight)
JWBerk94Z is offline
Old 12-13-2004, 10:55 AM
  #38
nateh's Avatar
Kook's uses 304 stainless. The coating will not stick as well to 304, so Nick is correct. 409 stainless is a lower grade ferritic stainless and coatings will stick much better. One nice thing about the 304 stainless is that if you want to work the surface, it will polish out to a mirror finish. 409 won't do that. Granted, it would be a lot of work to do this to headers, but it could be done, and they would look great.
nateh is offline
LT14LIFE
02-09-2015 09:35 PM
01-05-2015 07:14 PM
SpeedJunkee
12-09-2014 10:17 PM
Queens94z28
11-20-2014 06:03 PM
07-04-2005 05:00 PM
Quick Reply: Kook's LT1 long tubes finally arrived!! Pics inside
