Larger Lift Cam with 1.52 Rockers.... Does it Matter???
Before I order this cam I want to make sure I'm not making a no-no...
I want this cam TN-224HL 224/230 112 LSA
With 1.6 RR's the lift is .560/.598
I will be using 1.52 Promag's so the lift would be .532/.569 which is about exactly where I want the lift at..........
Also, this is an "XE" cam? TN-224HL
http://www.cmotorsports.com/engine/l...ft-design.html
No problem right?
Plus the 1.52's should clear the valve cover pretty well...
No problem right?
10-31-2016 11:09 AM
