Which larger OEM (Ford/GM) injectors fit the LT1?
Im in the market for some larger injectors to support my cam-only LT1. I know there are larger Ford/GM injectors that drop in the LT1, but I don't know where to start. I've been told the '03/04 Cobra injectors would work but Im not entirely sure, just need a cheap alternative to purchasing SVO's. Don't want to spend over $100 cuz I still need a retune.
So what are our options?
I agree, injectors are not needed in a cam only car. I'm at 375 rwhp heads/cam still running the stock injectors.
Also, good luck finding a decent used set of injectors for $100. FIC sells reconditioned Bosch III injectors for $185.
Cam only won't need an injector upgrade, I agree. There are deals on injectors everywhere but I wouldn't set a price limit at $100, more like $150 for a decent set of used injectors. I paid $130 shipped for my 30# SVOs off of this site with a few thousand miles on them.
You can increase the flow capacity of your stock injectors simply by raising the fuel pressure, with an AFPR. But as noted above, you probably don't need larger injectors with only a cam. On the other hand, if its running 114 MPH in the 1/4, it would appear to have more than a cam.
My car is gutted and has every single bolt-on which might account for the MPH. Im just stumped as to why the car fouls out plugs, it seems to only happen once I go WOT. After a fresh set of plugs and part throttle driving it runs fine.
My old TransAm did the same thing and never had problems after I installed some RX 32lbs injectors and a retune.
https://www.camaroz28.com/forums/sho...90&postcount=6
Great post about using GTP Injectors. I was able to get 8 injectors for like $35.
https://www.camaroz28.com/forums/sho...d.php?t=586705
Helpful thread.
You also indicated in the post above that you were running higher than stock fuel pressure, and that they are maxed out.
10-31-2016 11:09 AM
TheGreenZ28
Exhaust System
12-06-2014 10:23 PM
