LE2 355 finnaly finished
#31
Re: LE2 355 finnaly finished
LT1 KM... and yes it was showing that much at idel... maby i did not cut enough of my valve covers away for the RR's.. I looked and did not see any spots where it had been hitting?
#33
how could the cam be degreed wrong? I guess the only place where I could have actually adjusted the position of the cam was when i put the timing chain on... but i lined that up perfectly... afaik... but then again its probably not too perfect!
#35
Originally Posted by hallbilly
AH HA!!!!!!... waht if it is 100% correct and the 6-8 month old gas i have in there is causing it to detonate!?!?!?
#38
merry christmas to you as well... so could i just pour some 100+ octane gas in it and mix it around some... I dont think i can get away with draining the gas in the parking lot
#43
My friend is a chemist for conico phillips (76 gasoline) and she told me that the 10 month old 91 octane in my tank was no longer good ESPECIALLY in any high compression environment. Straight from the horses mouth (dont tell her i called her a horse) she works in the chem lab that formulates and quality controls the fuel we all use.
Steve
Steve
#44
awesome, im going to take it tonight and get some petro and pump up the tires and wash it off... then put around some... hopefully i can wash that crap out... HOPEFULLY it will not damage anything
