LE2 HEAD & CAM SETUP vs. Bottom end.
#16
The LE2 cam is fine for the 6500rpm range. I am working on a new B-Spec series of cams that all work out to be a tad smaller than the current LE cams. Smaller cams are not a bad thing at all, but what we have put out there now is fine for either of the stock rods. FWIW I think the PM's might be a better rod since that's the standard on LS1 rods and those can take slightly higher RPM 6800rpm and a longer stroke 3.622" vs. 3.480", but I do believe that the LS pistons are lighter than the LT stuff.
Bret
Bret
#17
Bret
Bret
What years got the PM rods? I'm planning to do some road coarse lapping days sometime later this year and the last thing I want to do is blow my motor on the track.
#18
Throw a blower on the stock bottom end with a small cam - leave the heads untouched, shift at 6200rpm - complete driveability, decent gas mileage, no need for an obnoxious gear (3.42 is great) and run sub 11's on pump gas.
10-31-2016 11:09 AM
NewsBot
01-29-2015 07:10 PM
