LE3 h/c vs. Adv. Ind. 200cc h/c
what are peoples experiences/thoughts on the LE3 h/c package vs. the Advanced Induction 200cc LT1 cast h/c package. which makes more power? any dyno graphs? thanks
You'll get nutswingers on both sides of the camp. You can't go wrong with either one of them, call both up and see who you like the best and compare prices and go from there.
Unless there is a LE3 head/cam stroker f-body car out there running 9.97 @ 138+ N/A and at 3470 pounds raceweight, the answer is fairly clear.
I can see it being a racecar and I could see it as a street car. I saw Ricks car run 10.0's as a small 383 (compared to a 396) back seats, and big ugly long mufflers kind of street car. Now I also saw the same car have a solid cam, no heat, and individual egt sensors in the primarys. The car ran good, but I bet the LE3 can do the same.
Lloyd has AWESOME customer service...that is worth a big amount of money to me......he took care of me when I had a few questions etc. I will do biz with him again.
You learn as you get older to stay with the people that treat you right, not saying that AI has any customer service problems, I have no idea.
But I HAVE seen people buy the best "deal" and get left pissing up a rope when they need help.
David
David
someone just needs to do an engine dyno test of each package in a controlled environment to settle all this...
I personally would go with lloyd becuase I have bought from him before and his service was excellent. he always went out of his way to answer my questions and help me out even a year after I purchased the combo from him. I also know that lloyd is always getting better. he told me that the heads he did for me (in fall of 2004) are about 20-30 hp behind what he puts out now.
Now, Im not saying Ai's service or quality is worse than lloyd's, I really dont have a clue so I can't comment.
look at lloyd's trans am for what can be done with a relatively simple build on a street car. he even bought a set of his own heads back instead of porting a set for himself!
You ever get your chit figured out? I see snazzy dyno numbers but no new ET's...
