Le3/Le2 H/C track times, Do I have a problem??
Old 07-02-2007, 06:53 AM
  #136
Tricked-Out-Toy's Avatar
3.70 is as low as ill go. I still run it alot, and road trips are a must and I wont sacrifice my cruising rpm for a few tenths of a second. plus I plan on spraying 150 as soon as I make a 11 second pass N/A and 3.70's will work very well with spray.
My burn out is in second and my best results were when I started the burnout in the water and slowly rolled out. the problem I was having was I would hit the rev limiter almost immediately and then peddle back and it would start to bog and grip and just push the front. it was like I couldnt spin the wheels fast enough in second?
Tricked-Out-Toy is offline
Old 07-02-2007, 11:40 AM
  #137
stereomandan's Avatar
Honestly, your driving looks fine to me. The launch is a tough one to master. Every time I go to the track, it requires a totally different stragegy for launch due to weather and track prep. I'm on street tires though, which is tough.
I agree that a front line-lock would help a ton with heating up the tires. Your tires should be able to get fairly hot without the line lock though.
Dan
stereomandan is offline
Old 07-02-2007, 11:44 AM
  #138
Sweetred95ta's Avatar
I thought so as well. Even without perfect launches, you should still be seeing much more mph.
Sweetred95ta is offline
Old 07-02-2007, 12:10 PM
  #139
Z-RATED94's Avatar
Listening to your runs, something doesn't sound right. Can't tell you what it is, but the motor sounds kind of flat. Your missing something, and sorry to say, I have no idea what it is.
Z-RATED94 is offline
Old 07-02-2007, 12:20 PM
  #140
speed_demon24's Avatar
DO NOT DO THE BURNOUT IN THE WATERBOX
Go around the water box, then back into it with your back tires. drop the clutch and let them spin over a couple times in the water to get the tires wet all around, then pull forward out of the waterbox and do a burnout.
speed_demon24 is offline
Old 07-02-2007, 01:29 PM
  #141
I should have explained it better. yes I drove around the water backed in spun the tires (rolled out) and got back in it. I was talking the the track guy and he said it fine to start in the water and roll out as long as your not sitting in the box.
I agree that it sounds "flat" I just don't know how to fix it. Im hoping with the changes Dan has made will help! it sure feels alot stronger and on my little T&T on ramp I was hitting 4th alot sooner than I normally do!
Old 07-02-2007, 01:39 PM
  #142
Glad to help. BTW, you have a new tune in your email inbox.
Dan
10-31-2016 11:09 AM
Feffman
10-09-2015 05:42 AM
Louey
Pacific
12-25-2014 03:27 AM
GRN96WS6
09-08-2002 10:45 PM
teedoff59
08-08-2002 01:36 AM
Quick Reply: Le3/Le2 H/C track times, Do I have a problem??
