Leaving a clowd...
Leaving a clowd...
I thought I'd throw this up here just to see what kind of general concensus I could get on my problem here. I just had a 383 LT4 built and put it in the car...turns out my LT4 intake had a pretty bad vaccum leak. Well I had noticed that my car was burning what seemed to be oil at idle. I would let it sit there, and it would just start smoking out the back, not too bad but bad enough where it would rise up over the car. Anyways, once I got a new LT4 intake on and sealed up all the vaccum leaks it now leaves a huge smoke screen when its just sitting there at idle...and now if you drive it, it spits out smoke too. So after all that, my question is, what things can cause this to happen? Did the rings not seat right? Head gasket problem? Something in the machining? I'm not sure, the car is going back to my builder tomorrow so hopefully everything will be ok. Thanks for reading the long post.
PS Engine has little over 500 miles on it.
Re: Leaving a clowd...
Have your heads been milled? Sounds like in both cases the intake manifold may not be seating properly to the heads/block. When you pulled the first intake off were the intake runners oily?
What was wrong with your LT4 intake to cause a vacuum leak to the extent that the entire manifold had to be replaced?
White smoke, blue smoke or black smoke?
Originally Posted by Daniel6718
could have double intake gasketed it...ive seen it done...although i wouldent...bc i dont know the reliability of that...or a grinder..lol
White smoke is generally associated with water or coolant getting into the combustion chamber. Does it smell like burnt coolant at the exhaust pipe?
WobblySausage
10-07-2015 10:09 AM
08-17-2015 09:50 AM
08-07-2015 08:52 AM
